Tasks in ImmyBot are powerful scripts that perform specific actions on computers. This guide explains how to create, manage, and deploy tasks effectively.
Understanding Tasks
Unlike software deployments, tasks:
- Don’t necessarily install anything
- Can be used for configuration, maintenance, or information gathering
- Can run in different contexts (System, User, Metascript, Cloud)
- Can be one-time, recurring, or compliance-based
Task Execution Contexts
ImmyBot supports four execution contexts for tasks:
System Context
- Runs with SYSTEM privileges on the computer
- Ideal for system-level changes and configurations
- Has access to all local resources
- Cannot interact with user interfaces
User Context
- Runs in the context of a specific user
- Ideal for user-specific configurations
- Can interact with user interfaces
- Limited to user permissions
- User must be logged in when scripts in this context run
Metascript Context
- Runs on the ImmyBot server
- Can orchestrate actions across multiple computers and across multiple contexts
- Ideal for coordinating complex workflows
- Must use Invoke-ImmyCommand to access computer resources
Cloud Context
- Runs exclusively on the ImmyBot Server
- Has access to cloud-specific APIs
- Ideal for interacting with cloud services
- Cannot directly access computer resources
Creating Tasks
Follow these steps to create a new task:
Navigate to Tasks
- Click on Tasks in the left sidebar
- Click Create Task
Enter Basic Information
- Enter a descriptive name for the task
- (Optional) Add a description
- Select the execution context (System, User, Metascript, Cloud)
Write the Script
- Write or paste your PowerShell script in the editor
- Use ImmyBot helper functions as needed
- Add comments to explain complex sections
If using a combined script, be sure to include a Switch on $Method that includes at least Test and Set, and optionally Get
Configure Parameters
- Click Add Parameter to create script parameters
- For each parameter:
- Enter a name
- Select a type (String, Number, Boolean, etc.)
- Set a default value (optional)
- Add a description
- Configure validation rules (optional)
Configure Success Criteria
- Define what constitutes successful execution
- Use your Test Script or Test Script Block to return $True if the execution was successful and $False if the execution was unsuccessful
Save the Task
- Click Save to create the task
- The task is now available for use in deployments
Task Examples
Here are some common task examples to help you get started:
System Context Example: Clear Temporary Files
# Clear temporary files to free up disk space
$FilesToDeleteCount = 0
$TempPathToFiles = Join-Path $TempFolder "*"
$FilesToDelete = Get-ChildItem $TempPathToFiles -Recurse -Force # Check for files to delete
$FilesToDeleteCount = $FilesToDelete | measure | select -Expand Count # Count how many need to be deleted for testing
switch($method)
'test'
# If files are found that need to be deleted this will return $True and trigger the Set phase if appropriate
$FilesToDeleteCount -eq 0
'set'
$FilesToDelete.FullName | Out-String
$FilesToDelete | Remove-Item -Recurse -Force -ErrorAction SilentlyContinue
Write-Host "Deleted $FilesToDeleteCount file(s) from $TempPathToFiles"
User Context Example: Get Signed In User’s UPN
Since User context scripts will fail if the user is not signed in, running them as metascripts and using Invoke-ImmyCommand -Context User can provide better error handling.
try {
Invoke-ImmyCommand -Context User {
$userDomain = $env:USERDOMAIN
$computerName = $env:COMPUTERNAME
if ($userDomain -ne $computerName) {
whoami /upn
} -ErrorAction Stop
} catch {
if ($_.FullyQualifiedErrorId -eq "Immybot.Agent.MinimalShared.NoLoggedOnUserException" -or
$_.FullyQualifiedErrorId -eq "OperationTimeout") {
$_
$Error[0] = $null
throw
Metascript Example: Reset-Outlook Profile
[CmdletBinding(DefaultParameterSetName = 'AllUsers')]
param([string]$ProfileName = 'Outlook',
[Parameter(Mandatory=$False, ParameterSetName='AllUsers')]
[switch]$AllUsers,
[Parameter(Mandatory=$False, ParameterSetName='LoggedOnUser')]
[switch]$LoggedOnUser)
if($AllUsers){
$LoggedOnUser = $false
switch($method){
'test' {
$OutlookTest = Invoke-HKCU -LimitToSID ($ProfilesToMigrate.SID) -ScriptBlock {
$BasePath = 'HKCU:\SOFTWARE\Microsoft\Office'
$ZeroConfigValue = Get-ItemProperty -Path "$BasePath\AutoDiscover" -Name ZeroConfigExchange -ErrorAction SilentlyContinue | %{$_.ZeroConfigExchange}
if($ZeroConfigValue -ne 1)
Write-Warning "Outlook: ZeroConfigValue not equal 1: $ZeroConfigValue"
return $false
$ProfilesExists = Test-Path "$BasePath\16.0\Outlook\Profiles"
if($ProfilesExists)
Write-Warning "Outlook: Profiles exist: $ProfilesExists"
return $false
$FirstRun = Get-ItemProperty -Path "$BasePath\16.0\Outlook\Setup" -Name 'First-Run' -ErrorAction SilentlyContinue | %{$_.'First-Run'}
if($FirstRun)
Write-Warning "Outlook: First-Run Exists"
return $false
return $true
Write-Host "OutlookTest: $OutlookTest"
if($OutlookTest -eq $false)
Write-Warning "Outlook needs to be reconfigured"
$Status = $false
'set'{
Write-Host "Ensuring Outlook is not running"
Invoke-ImmyCommand { taskkill /im outlook.exe /f 2>&1 | Out-Null }
Invoke-HKCU -LimitToLoggedOnUser:($LoggedOnUser) -ScriptBlock {
$ProfileName = $using:ProfileName
$OutlookRegistryPath = "HKCU:\SOFTWARE\Microsoft\Office\16.0\Outlook"
$OldDefaultProfile = Get-ItemProperty -Path $OutlookRegistryPath -Name DefaultProfile | %{$_.DefaultProfile}
$OldDefaultProfileRegistryPath = "$OutlookRegistryPath\Profiles\$OldDefaultProfile"
$NewDefaultProfileRegistryPath = "$OutlookRegistryPath\Profiles\$ProfileName"
$NewOldProfileName = $OldDefaultProfile
while((Test-Path "$OutlookRegistryPath\Profiles\$NewOldProfileName"))
$NewOldProfileName = "_" + $NewOldProfileName
if($OldDefaultProfile -ne $NewOldProfileName)
Write-Host "Desired ProfileName $ProfileName already exists, renaming to $NewOldProfileName"
Rename-Item -Path $OldDefaultProfileRegistryPath -NewName $NewOldProfileName -ErrorAction SilentlyContinue
Write-Host "Creating Outlook profile $ProfileName"
New-Item -Path $NewDefaultProfileRegistryPath -Force | Out-Null
Write-Host "Setting $ProfileName as Default"
Set-ItemProperty -Path $OutlookRegistryPath -Name DefaultProfile -Value $ProfileName
Write-Host "Renaming First-Run to _First-Run"
Rename-ItemProperty -Path "HKCU:\SOFTWARE\Microsoft\Office\16.0\Outlook\Setup\" -Name 'First-Run' -NewName '_First-Run' -ErrorAction SilentlyContinue
if (!(Test-Path "HKCU:\SOFTWARE\Microsoft\Office\AutoDiscover\"))
New-Item "HKCU:\SOFTWARE\Microsoft\Office\AutoDiscover\" -Force | Out-Null
Write-Host "Setting ZeroConfigExchange to 1"
New-ItemProperty -PropertyType DWord -Path "HKCU:\SOFTWARE\Microsoft\Office\AutoDiscover\" -Name ZeroConfigExchange -Value 1 -ErrorAction SilentlyContinue | Out-Null
Task Best Practices
Follow these best practices for effective task management:
- Use Descriptive Names: Make task names clear and specific
- Add Comments: Document your scripts and tasks with comments and descriptions
- Handle Errors: Include error handling in your scripts
- Test Thoroughly: Test tasks on a small set of computers before deploying widely
- Use Parameters: Make tasks flexible with parameters
- Log Actions: Include logging in your scripts
- Idempotence: Design tasks to be safely re-runnable
Troubleshooting Tasks
If a task isn’t working as expected:
- Check Logs: Review the task execution logs
- Test with Script Debugger: Run the script using the script debugger in Immybot
- Check Permissions: Ensure the task has the necessary permissions
- Verify Context: Confirm you’re using the appropriate execution context
- Debug Mode: Add debug output to your script
- Simplify: Break complex tasks into smaller, simpler tasks
Next Steps
Now that you understand how to work with tasks in ImmyBot, you might want to explore:
- Scripting Guide – Master the art of scripting in ImmyBot
- Metascripts / Cloud Scripts – Learn about advanced scripting capabilities
- Common Workflows – See examples of common task scenarios
