Configure Directory
This document will go over setting up, using, and troubleshooting the task Configure Directory.
Configure Directory is a combination of Set Computer Name and Domain Join and AzureAD Join. We utilize the access that ImmyBot has to determine if you’re tenants are using Active Directory, or AzureAD. Similar to Set Computer Name and Domain Join, you have the choice of joining a domain at all.
This task is intended to replace Join AzureAD and Set Computer Name and Domain Join. If you’re trying to add a computer to a domain, change the name, etc, utilize this task.
Deployment Planning
You can set up a Cross Tenant deployment for local Active Directory joins, the task will automatically utilize the Domain Controller in the tenant. If you plan on doing any AzureAD Joining, you will need to set up a single tenant deployment per tenant.
If you only want to maintain a naming convention, just set DirectoryType to None, and set up your naming convention.
Permissions to configure Deployments
You will need to set up a DEM user for each of your tenants if you’re planning on joining to AzureAD.
If you need to add the computers to AzureAD, you need to set up automatic Intune Enrollment
If you’re using local Active Directory, you will need Domain Controllers with the permanent agent installed.
Parameters
NameDescriptionRecommendation
PrimaryPersonThis will be used to determine what software to install based on licensing in 365 and the groups the user is in.For Cross Tenant Deployments, leave default
Directory TypeChoose is this is a local Active Directory, Azure Active Directory, or if you don’t want this deployment to join a domain.For Cross tenant Deployments, leave default
ComputerNameTemplateThe templated computer naming scheme for your tenants. Supports tokens, more information belowFor Cross Tenant Deployments, utilize Tenant Slug where possible.
Username TemplateLeave default
PreferredDomainControllerNameIf you would like to specify a specific domain controller to use, configure that hereLeave default
CacheProvisioningPackageSet to True
SkipRegistryTestSkips registry validation and modification steps required for Azure AD Join.Use this if registry settings are confirmed correct or for testing purposes, otherwise leave default
ClearExistingEnrollmentsSet this to clear all existing enrollments before joining (including User/Workplace Joins).Leave Default
UseEnhancedAzureADJoinUse certificate based Azure AD join instead of PPKG.Set up and enable
Computer Name Template
Supported Tokens:
TokenExample
$TenantSlugABC (Specified under Tenant -> Edit)
$FirstInitialJ
$FirstNameJohn
$LastNameDoe
$LastInitialD
$ManufacturerDell, Lenovo, etc
$SerialNumberService Tag on Dell Devices, otherwise serial number on device
$FormFactorShortPC/LPTP/SFC/VM
$FormFactorLongDESKTOP/LAPTOP/ SURFACE/VIRTUAL
$YearCurrent Year, 2025
$YearShortCurrent Year, 25
$AssetTagEnter manually
#1
##01
###001
Examples
$TenantSlug-$FormFactorShort-### -> ABC-PC-001
$TenantSlug-$FirstInitial$LastName -> ABC-JDOE
$SerialNumber-$Year-### -> ABC123-2025-001
Troubleshooting
Join Issues
MFA Prohibiting AAD Joins (0xCAA2000C):
If your conditional access policies require MFA for all users, adjust the settings as follows:
  1. Exclude ‘Microsoft Intune Enrollment’ from the Cloud Apps requiring MFA.
  2. In Azure AD, create a Dynamic Security Group named ‘Provisioning Packages’.
    Set its Dynamic Membership Rule to: user.userPrincipalName -startsWith “package_”
  3. Ensure that this ‘Provisioning Packages’ group is excluded from the MFA requirement.
Azure SyncFabric App
This cloud app needs to exist for the task to run properly. Many new environments do not have the app when they are created, so you will need to create them. Microsoft has also been known to occasionally remove the app from tenants that already have it.
To add the cloud app to the desired tenant, run the following script:
#Install-Module AzureAD #Uncomment this if you do not already have the AzureAD module installed
Import-Module AzureAD
Connect-AzureAd -TenantId contoso.com # Login as Global admin in customer tenant
New-AzureADServicePrincipal -AppId 00000014-0000-0000-c000-000000000000
Warning
Replace the “contoso.com” domain with the one corresponding to your desired tenant.
Alternatively, there is a cloud task that can add Azure SyncFabric back to the tenant. It may require a custom app registration, though.
Known Error Codes
0xCAA10059
The account (DEM) you are using to enroll the device does not have permissions to join devices to Azure AD. Add the account to ‘Selected Users’ or enable ‘Allow All’ users to join devices at:
Microsoft Entra ID – Device Settings
0xCAA50021
The AAD Broker Plugin has been reset by us. You’ll need to re-run the task if you see this.
0x8018000A
The device is already enrolled by a user. Re-run with ‘ClearExistingEnrollments’ set to ‘True’.
0x801C0024
The package_ AAD user associated with the PPKG was not found. Please run again with ‘CacheProvisioningPackage’ set to ‘False’ to generate a new package and user. This one shouldn’t be an issue anymore, since we implemented retries that will generate a new package user if we are unable to create a token on the first try.
0x800700B7
The provisioning package already exists. This may happen if you have executed the provisioning package earlier on this machine.
AADSTS90092 or AADSTS90202
This tenant is missing the Microsoft.Graph.SyncFabric app (Microsoft stopped including it at some point in life)
Refer to Azure SyncFabric App
AADSTS240005
To correct this, navigate to Intune – Roles
Assign the Cloud Device Administrator or Cloud PC Administrator role to the DEM account you are using and try again.
AADSTS50126
The credentials are invalid OR the user has not been excluded from your Registration Campaign
Microsoft Entra Admin Center – Registration Campaign
AADSTS50055
Reset the user’s password via Microsoft Admin Center
AADSTS240003
This issue might be related to Multi-Factor Authentication (MFA) being enabled for $Username.
It’s recommended to disable MFA for this account or consider using OAuth for a more secure authentication method.
AADSTS90002
This error can typically be resolved by using the OAuth flow instead of the username/password flow.
Directory Migration
