Tenants represent your customers or client organizations in ImmyBot. Each tenant is a separate entity with its own computers, users, and configurations.
- Tenants can be created manually or synced automatically from external systems
- We recommend syncing Tenants from ConnectWise Automate, Microsoft Azure, or other supported integrations
- Tenants can be organized in a hierarchical structure with parent-child relationships
- Each tenant can have its own specific settings, deployments, and maintenance windows
Tenant List
All columns have a search and filter function, as well as the ability to sort said columns. You can also create new tenants manually here, and run batch actions against a selection of tenants.
New tenants can be created manually, however we do recommend you manage tenant creation through an integration. Please see Tenant Management
Bulk actions allow you to make mass changes to tenant preferences to streamline your tenant management where necessary.
Tenant Structure
When you click into a tenant you will see any tags associated with the tenant at the top, and a list of tabs that pertain to the contents of the tenant or the preferences you’ve set for the tenant. From this page you can:
- Computers – Manage computers individually and en masse
- Sessions – Review sessions for the tenant
- Actions – Review actions taken against the tenant
- Software Review and deploy software across the computers in the tenant
- Software Search Search for software that exists in the tenant’s endpoints
- Schedules – Manage schedules for deployments
- Preferences – Set the preferences such as business hours, time zone, and cross tenant deployment participation
- Edit – Edit the tenant name, slug, parent tenat, tags
- Azure – Manage and test the Azure connection
