This comprehensive guide explains the powerful scripting capabilities available in ImmyBot through Metascripts, Cloud Scripts, and their associated commands.
Understanding Server-Side Scripts
Metascripts
A Metascript is a PowerShell script that runs in the ImmyBot backend and can execute commands on remote computers. Metascripts provide a powerful way to orchestrate actions across multiple devices while maintaining state in the ImmyBot backend.
Key capabilities of Metascripts:
- Execute commands on remote computers
- Pass objects between the server and client
- Maintain context across reboots
- Access ImmyBot’s internal APIs and data
Example: Comparing PowerShell Versions
$ServerPSVersionTable = $PSVersionTable
$ComputerPSVersionTable = Invoke-ImmyCommand {
$ServerPSVersionTable = $using:ServerPSVersionTable
Write-Host "Running from $env:ComputerName but ImmyBot backend is running PowerShell $($ServerPSVersionTable.PSVersion)" -ForegroundColor Green
return $PSVersionTable
$VerbosePreference = 'Continue'
Write-Verbose "Running from ImmyBot backend, but the computer is running Windows PowerShell $($ComputerPSVersionTable.PSVersion)"
Output
Invoke-ImmyCommand is modeled after PowerShell’s native Invoke-Command, with the ability to pass real objects into and out of the remote runspace while preserving stream information. This approach is superior to capturing standard output and standard error as strings, which is common in many automation tools.
Cloud Scripts
Cloud Scripts are similar to Metascripts but target a Tenant instead of a specific computer. They’re particularly useful for:
- Managing tenant-wide settings
- Interacting with cloud services like Microsoft 365
- Performing operations across all computers in a tenant
- Manipulating settings in each customer’s Azure environment
Collectively, Metascripts and Cloud Scripts are referred to as “server-side scripts” in ImmyBot.
Common Commands
These commands are available in all server-side scripts.
Azure Integration Commands
Connect-ImmyAzureAD
Provides a wrapper around Connect-AzureAD to authenticate with Azure AD.
# Authenticate with Azure AD and retrieve all users Connect-ImmyAzureAD $users = Get-AzureADUser -All $true Write-Host "Found $($users.Count) users in Azure AD"
Documentation: Microsoft Connect-AzureAD Reference
Get-ImmyAzureAuthHeader
Obtains an authentication header for the specified Microsoft endpoint.
Usage
Get-ImmyAzureAuthHeader [-Endpoint] <["MSGraph", "AzureAD"]>
Example
# Get authentication header for Microsoft Graph API $Header = Get-ImmyAzureAuthHeader -Endpoint "MSGraph" -ErrorAction Stop # Use the header to make a Graph API request $Groups = Invoke-RestMethod "https://graph.microsoft.com/v1.0/groups/" -Headers $Header Write-Host "Found $($Groups.value.Count) groups in Azure AD"
Parameters:
-Endpoint: Accepts either “MSGraph” or “AzureAD”
Returns: A dictionary containing the authentication header
RMM Integration Commands
Get-ProviderInfo
Retrieves an instance of an RMM Provider for the specified type.
Alias: Get-RmmInfo
Usage
Get-ProviderInfo [[-ProviderType] <string>] [-IncludeClients] [<CommonParameters>]
Example
# Get information about the ConnectWise Automate integration $RmmInfo = Get-ProviderInfo -ProviderType CWAutomate Write-Host "Connected to $($RmmInfo.Provider.Name) at $($RmmInfo.Provider.Url)"
Parameters:
-ProviderType: The type of RMM provider (e.g., “CWAutomate”, “NinjaRMM”)-IncludeClients: Include client information from the RMM
Example: Updating a ConnectWise Automate EDF Field
[string]$FieldName,
[string]$Value,
$Computer
# Get the current computer if not specified
if(!$Computer) {
$Computer = Get-ImmyComputer
# Get the RMM computer and provider information
$RmmComputer = Get-RmmComputer -Computer $Computer -ProviderType CWAutomate
# Find the EDF field
$EDF = Get-CWAComputerEDF -FieldName $FieldName -Computer $Computer
if(!$EDF) {
Write-Warning "Aborting: Unable to find EDF $FieldName"
return
# Update the EDF field value
$ExtraFieldDefinitionId = $EDF.ExtraFieldDefinitionId
$ValueProperty = $EDF | Select-Object *FieldSettings* | Get-Member -MemberType NoteProperty | Select-Object -First 1 | ForEach-Object {$_.Name}
$PatchPath = "$ValueProperty/Value"
$Uri = "cwa/api/v1/computers/$($RmmComputer.RmmDeviceId)/extrafields/$ExtraFieldDefinitionId"
$Body = ConvertTo-Json @(@{"op"="replace";"path"=$PatchPath;"value"=$Value})
Invoke-CWARestMethod $Uri -Provider $RmmInfo.Provider -Method PATCH -Body $Body
Metascript Commands
Remote Execution
Invoke-ImmyCommand
A powerful command that allows you to execute scripts remotely on devices.
Usage
Invoke-ImmyCommand [-ScriptBlock] <Object> [-Computer <PSComputer>] [-Context <string>] [-ArgumentList <array>] [-Timeout <int>] [-ConnectTimeout <int>] [-DisableConnectTimeoutWarnings] [-Parallel] [<CommonParameters>]
-Context accepts either “System” or “User”
-Timeout accepts an integer denoted in seconds. The default is 120.
-Parallel (switch, makes the script block run on all the computers simultaneously instead of in series)
-ConnectTimeout (integer, seconds, to override the amount of time before giving up on trying to start the script on a computer)
-DisableConnectTimeoutWarnings (switch, to suppress “WARNING: Timed out waiting for script to start on COMPUTER” for every computer that fails to start within the connect timeout).
Examples
# Basic example - run a command on the current computer
Write-Output "Hello from $env:COMPUTERNAME"
Get-Service | Where-Object { $_.Status -eq 'Running' } | Select-Object -First 5
# Run a command on all workstations in parallel
Get-ImmyComputer -TargetGroupFilter Workstations | Invoke-ImmyCommand -Parallel {
$ComputerInfo = Get-ComputerInfo
[PSCustomObject]@{
ComputerName = $env:COMPUTERNAME
OSVersion = $ComputerInfo.OsVersion
LastBoot = $ComputerInfo.OsLastBootUpTime
FreeMemory = [math]::Round($ComputerInfo.OsFreePhysicalMemory / 1MB, 2)
} | Format-Table -AutoSize
Parameters:
-ScriptBlock: The PowerShell script to execute remotely-Computer: The target computer(s) to run the script on-Context: Either “System” (default) or “User” execution context-ArgumentList: Arguments to pass to the script-Timeout: Maximum execution time in seconds (default: 120)-ConnectTimeout: Time to wait for connection in seconds-DisableConnectTimeoutWarnings: Suppress timeout warnings-Parallel: Run the script on all computers simultaneously
Using the $using Scope Modifier:
The $using scope modifier allows you to reference variables from the calling script in your remote script block:
$AppName = "Microsoft Office"
$Results = Invoke-ImmyCommand {
$App = Get-WmiObject -Class Win32_Product | Where-Object { $_.Name -like "*$using:AppName*" }
if ($App) {
return [PSCustomObject]@{
Name = $App.Name
Version = $App.Version
Installed = $true
Name = $using:AppName
Version = $null
Installed = $false
Email Notifications
Send-ImmyEmail
Sends an ImmyBot-styled email to specified recipients.
Send-ImmyEmail [-Subject] <string> [-Body] <string> [[-To] <List[string]>] [[-Bcc] <List[string]>]
# Send an email to the default recipients (based on maintenance session settings)
Send-ImmyEmail -Subject "Weekly Maintenance Report" -Body "All systems have been updated successfully."
# Send an email to specific recipients
Send-ImmyEmail -Subject "Critical Update Required" -Body "Please approve the pending update." -To @("admin@example.com", "manager@example.com")
Parameters:
-Subject: Email subject line-Body: Email body content (can be HTML)-To: List of email addresses to send to-Bcc: List of email addresses to BCC
Computer Management
Refresh-ComputerSystemInfo
Updates ImmyBot’s inventory information for the specified computer.
# Refresh information for the current computer Refresh-ComputerSystemInfo # Refresh information for all servers Get-ImmyComputer -TargetGroupFilter Servers | Refresh-ComputerSystemInfo
This command updates the following computer information:
- ComputerName
- SerialNumber
- ChassisTypes
- DomainRole
- Domain
- OsName
- OsInstallDate
- LastBootTime
- Model
- Manufacturer
Parameters:
-Computer: The computer to refresh information for (defaults to current session computer)
Get-RmmComputer
Retrieves RMM-specific information about a computer.
# Get RMM information for the current computer $RmmComputer = Get-RmmComputer Write-Host "RMM Device ID: $($RmmComputer.RmmDeviceId)"
Get-ImmyComputer
Retrieves ImmyBot computer objects.
# Get all computers in the current tenant
$Computers = Get-ImmyComputer
Write-Host "Found $($Computers.Count) computers in the tenant"
# Get computers with specific inventory values
$WindowsComputers = Get-ImmyComputer -InventoryKeys @("OsName=Windows 10*")
Filterscript Commands
Get-ImmyComputer
Returns a list of computers for the specified tenant, or all computers if it is cross-tenant scoped.
# Get all Windows 10 computers
Get-ImmyComputer -InventoryKeys WindowsSystemInfo | Where-Object {$_.Inventory.WindowsSystemInfo.OsName -like "*Windows*10*" }
# Get all Dell computers
Get-ImmyComputer -InventoryKeys WindowsSystemInfo | Where-Object {$_.Inventory.WindowsSystemInfo.Manufacturer -like "*Dell*" }
Parameters:
-InventoryKeys: Array of inventory key-value pairs to filter by
When working with ImmyBot commands, consider these best practices:
Error Handling: Always include proper error handling in your scripts
try {
$result = Invoke-ImmyCommand { Get-Service WinRM } -ErrorAction Stop
} catch {
Write-Error "Failed to execute command: $_"
Timeout Management: Set appropriate timeouts for long-running operations
Invoke-ImmyCommand { Start-Process -FilePath "C:\Setup.exe" -Wait } -Timeout 300
Parallel Execution: Use the -Parallel parameter for bulk operations
Get-ImmyComputer -TargetGroupFilter All | Invoke-ImmyCommand -Parallel { Get-HotFix }
Variable Scope: Use the $using: scope modifier to reference local variables
$appName = "Chrome"
Invoke-ImmyCommand { Get-Process -Name "*$using:appName*" }
Context Awareness: Specify the appropriate context for your commands
# Run in system context (default)
Invoke-ImmyCommand { Get-Service } -Context System
# Run in user context
Invoke-ImmyCommand { Get-Process } -Context User
